Volvo S60 2013 - new Xexon HID headlight - needs ballast?
Old Feb 11, 2023 | 08:09 AM
volvo418's Avatar
Default Volvo S60 2013 - new Xexon HID headlight - needs ballast?
I installed a new Xexon HID headlight on my Volvo S60 2013. It does not work. Could this be because it hasn't been programmed, or is it possibly the ballast/igniter wire? The old headlight did not work either (condensation/water in the headlight - did not try a new bulb).
Old Feb 12, 2023 | 10:44 PM
ssicarman's Avatar
There are likely control modules on the headlamp assembly and if you had enough water in the headlamp you may have corrosion on/in connectors for them causing the problem.
Old Feb 22, 2023 | 01:01 PM
Mathieu Colins's Avatar
Originally Posted by volvo418
I installed a new Xexon HID headlight on my Volvo S60 2013. It does not work. Could this be because it hasn't been 192.168.100.1 192.168.1.1 programmed, or is it possibly the ballast/igniter wire? The old headlight did not work either (condensation/water in the headlight - did not try a new bulb).
Did you check all the wirings correctly ?
volvo418
Feb 8, 2023 12:41 PM
volvo418
Jan 13, 2023 10:48 PM
Sawyer Avery
Oct 29, 2020 03:46 PM
PsIloveU
Nov 14, 2010 12:45 AM
pvivier777
Sep 6, 2010 09:26 AM
