white smoke
Old Nov 3, 2010 | 12:05 PM
redvolvonyc's Avatar
Default white smoke
White smoke keeps coming out the exhust on my 2000 s40 . It started in the spring. but went away during the summer. Now that it's cold it started again. Someone told me it could be that the turbo needs to be replaced????
Please help
Old Nov 3, 2010 | 04:36 PM
740_300K's Avatar
Usually white smoke would indicate that the engine is drinking coolant. But, in this case, it's normal. When it gets cold out, it's the hot exhaust meeting the cold air, and condensating. I'd say it is nothing to worry about.
Old Nov 3, 2010 | 04:45 PM
swiftjustice44's Avatar
Smoke color and what it means
  1. Black- Fuel Mixture rich
  2. Blue- Oil burning
  3. Brown- Carbon build up breaking loose
  4. White- Moisture, water or engine coolant- transmission fluid burns white also but that is seldom introduced into combustion inadvertantly
While a failing turbo can indeed smoke white, more likely your car is simply getting moisture condensation in the exhaust system. If the smoke is limited to start up and is only for a minute or so, it's condensation. Typical times are if you shut the warm car down in the evening with high humidity and crank it the next morning. Hot exhaust, cold humid air...condensation every time.
Old Nov 3, 2010 | 06:20 PM
+1 With above statements. The white smoke should clear up within 5 minutes of driving.
Pv12345
Oct 11, 2007 08:33 AM
V8SRSLO
May 9, 2007 05:57 AM
justben714
Jan 27, 2007 11:02 AM
jay philoon
Nov 6, 2005 03:41 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
