Window down c70 2001 Volvo V5 Coupe HPT
Old Oct 19, 2012 | 02:24 PM
Offett's Avatar
Default Window down c70 2001 Volvo V5 Coupe HPT
Greetings to all,
I have removed the regulator and pulley system from within my drivers side door. I am attempting to raise the window so I can then remove the entire frame and substitute with new frame, regulator, and pulley. However, the window slides will not move. The window feels binded and no matter how hard a pull up on window from within door the window does not freely move. Please keep in mind that the pulley and regulator have been removed. Is it possible to raise window manually, or will I need to install regulator and pulley as is to raise window?
See pic below:
http://i1059.photobucket.com/albums/...WindowDown.jpg.
I have read previous threads and none appeared similar. If the window is already raised this is easy cause I ve done it before. The entire assembly simple comes out. With window down, I am stuck and running out of ideas. Please help thank you.
240-FAN
Aug 21, 2014 06:27 AM
T1G3R
Jul 22, 2013 08:28 PM
bimmerd00d
Aug 15, 2012 01:04 PM
schoolboy
Nov 9, 2011 04:17 PM
russcarp
Mar 19, 2011 02:43 PM
