1990 Volvo 240 dl No Brake Lights
Old May 7, 2021 | 02:20 AM
cdltnla's Avatar
Default 1990 Volvo 240 dl No Brake Lights
Hey, all,
I'll give the rundown... Grateful for any insight. :
Brake lights, including third, do NOT work.
***Tail lights and all other lights work.
***Cruise control works.***
***Turn signals work.
New tail light assemblies/new bulbs.
New fuses.
***Driver's side wiring connector, that connects to tail light circuitry board, has burn mark where fog light wires attach. ***Fog lights work.
Does anything stand out to be the brake light switch or bulb failure relay, possibly?
What brake wires go through hinges?
>>>I've read only the third brake light, does.
Does the third brake light wire connect to the lower/back brake light wires (is there a junction point we should look for a disconnection or bad wire?) and, do they all connect to that burnt wiring connector that attaches to driver's side tail light assembly?
I know this is alot of info. What's key to me is that the cruise control works. If it was a bad brake light switch or bulb failure relay, wouldn't the cruise control not work??
​​​​​Appreciate any opinions and guidance. Thank you so much for your help!
Mom & Son
P.S. Incredible forum. We've been able to replace tail light assemblies (were haggard as hell, anyway) and get easy access to brake switch and bulb failure relay, with your help, thus far! 🙏
We also made progress with getting reverse lights to function by messing with the shifter. (Assuming that's an adjustment, within. Will pursue.)
It's been fun and informative! Now, my son's considering furthering his Volvo mechanic education! 👍
We're just now, today, trying to get to know how to use a multi-meter and test light, at this point of our journey. Looking forward to learning!
cdltnla
May 6, 2021 11:43 PM
zhandfull
Jul 30, 2012 09:17 PM
craigshensel
Jun 13, 2012 03:11 PM
jon53
Oct 1, 2010 09:42 PM
dldunckel
Jan 20, 2010 07:02 PM
