1990 Volvo 240 Electrical Problems Need Help
Old Dec 13, 2015 | 11:05 AM
Moose On The Loose's Avatar
Default 1990 Volvo 240 Electrical Problems Need Help
I have a 1990 Volvo 240 dl wagon with electrical problems. It will start but within minutes the car dies. I have a new battery and a refurbished alternator. I checked to see if the voltage regulator was bad and it still has life in it. The little red wire on the alternator was cut but I reconnected it. It didn't solve the problem and the dash lights still won't turn on. I then noticed that there was a blue (negative ground) wire hanging freely by the radiator. It is the long ground off the negative battery terminal. I assumed it went to the starter but when I attached it, the positive wire and negative arched. I tried replacing the starter because the car wouldn't start but once I removed the negative wire it started fine.
My question is where does this battery ground go and can anyone show or tell me the correct starter wiring. Currently, I have two positive red wires stacked on the positive solenoid terminal. I am uncertain that this is correct because the wiring was all messed up when I got it.
Any help would be appreciated greatly! Thanks
IMAGES: MooseontheL0ose's uploaded images - Imgur
Faith Ross Buries
Dec 11, 2015 07:46 PM
jonqu
Sep 14, 2014 11:17 PM
craigshensel
Jun 13, 2012 03:11 PM
dldunckel
Jan 20, 2010 07:02 PM
likesspace
Jun 18, 2007 11:11 AM
