need serious answer please! 2000 Volvo S70 with electrical problems.
Old Apr 28, 2015 | 08:12 PM
Faith Ross Buries's Avatar
Default need serious answer please! 2000 Volvo S70 with electrical problems.
2000 s70 Volvo...windows, sun roof, rear view windows and air won't work. can someone tell me how to fix this problem!!!
Old Apr 28, 2015 | 09:10 PM
Check fuse 9 in the main fuse box. Its a 60A fuse. There's also a circuit breaker in the supplemental fuse box position 37. Check if that's been tripped. That does both the power windows and sun roof.
Old Oct 19, 2015 | 03:47 PM
vtowntech's Avatar
Default p1631 code is set and i clear it but it comes back aaaaah.
My s80 t6 is in limp mode,the instrument cluster does not show what gear the car is in it just shows a dash.The gear shifter is not illuminating the indicator and when I step on the brake pedal the safety switch does nothing.P1631 is stored I replaced the shifter unit still same. Any thoughts would be greatly appreciated.😧
Old Oct 19, 2015 | 06:18 PM
Koondaddy's Avatar
So my 06 S60 had the same problem bad valve body I just replaced the whole transmission was costly but luckily for me I had a warranty and we raped them.!! Goodluck bro
Old Oct 19, 2015 | 09:53 PM
PMOURASSA's Avatar
STOP hijacking other people,s Posts.
Old Oct 19, 2015 | 10:52 PM
Koondaddy's Avatar
**** u I replied my thoughts thru my experience. That's what's these forums are for
Old Oct 20, 2015 | 09:42 PM
PMOURASSA's Avatar
bad valve body
WHAT DOES THIS HAVE TO DO with his ISSUE?
Old Dec 11, 2015 | 07:46 PM
MNWILD
Sep 10, 2020 11:29 AM
KellyW.
Jul 11, 2016 12:03 PM
djoker04
Jun 22, 2011 09:28 AM
Bradhobbs
Mar 5, 2009 12:33 AM
jpbaily1
Oct 18, 2007 10:59 AM
