2001 Volvo V70 no crank no start
Old Mar 22, 2017 | 08:11 PM
James Hemsworth's Avatar
Default 2001 Volvo V70 no crank no start
I have been dealing with this problem for a couple weeks I have searched multiple posts and seen this is a common problem however cannot find a resolution through everything that is posted. However I have no power to the solenoid wire when cranking ignition switches good antenna ring has been replaced I am getting a code TCM 012 a TCM 012-b neutral check faulty connection. Is this the PNP switch? Can I test it/ bypass to test? Even running 12 volts to the solenoid wire won't get the car to actually start I have fuel pressure at the rail but no injectors spraying. Could the ECU be preventing the starter and injectors to operate? Any help would be greatly appreciated as I am in Alaska,no dealership here.
Old Mar 22, 2017 | 08:56 PM
ES6T's Avatar
Is the starter relay working properly?
Old Mar 23, 2017 | 12:11 PM
it is working.
Old Mar 23, 2017 | 12:26 PM
ES6T's Avatar
So you have power from the relay but not at the solenoid?
The problem is between the two.
fallen.angel
Nov 19, 2014 09:45 PM
Lavid2002
May 26, 2011 06:00 AM
Lavid2002
Mar 1, 2011 06:20 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
