2002 V70 indicator bulb replacement.
Old Apr 11, 2021 | 11:43 AM
ryoc's Avatar
Default 2002 V70 indicator bulb replacement.
Hi all, first week of owning a 2002 V70. Very pleased with the car too. The (passenger side UK model) front indicator headlight lense is badly misted. Is there an 'easy' way to get the bulb out to dry the lense? Looks really tight in there with not much room for manoeuvre. Thanks!
Old Apr 11, 2021 | 06:36 PM
If it's a glass headlamp lens - moisture can collect due to the turn indicator bulb socket leaking or not having a gasket - they are slightly difficult to remove - if really wet inside removing the headlamp assembly is the best bet.
Old Apr 12, 2021 | 04:40 AM
ryoc's Avatar
Hi and thanks. The whole headlight assembly was very wet, but I drilled a 10mm hole at the back of each of the headlight/side light plastic back covers. This worked a treat and has completely cleared them in a couple od days.. Just the indicator lense to clear now. All the best.
jeprox
Sep 23, 2017 12:27 PM
Newport_j
Jan 20, 2015 08:48 AM
xxgolfpro
Nov 8, 2008 09:21 AM
curtisckey
Feb 9, 2008 04:25 PM
dcjcdc
Jan 8, 2006 11:50 AM
