replacing headlight ?
Old Jan 7, 2006 | 04:25 PM
dcjcdc's Avatar
Default replacing headlight ?
hi ...the fromt passenger headlight is not working,,the highbeam is working....this is the 2002 s 40 turbo automatic
- is it hard to replace or do i bring it into the shop..also is it just the bulb you change or is it the whole assembley..thanks
Old Jan 7, 2006 | 09:19 PM
Default RE: replacing headlight ?
You only change the bulb should only take about 5-10 min.
Old Jan 8, 2006 | 09:17 AM
Black Beauty T4's Avatar
Do remember not to touch the glass of the new bulb with your bare fingers, otherwise you will significantly shorten the life of the bulb.
BB
Old Jan 8, 2006 | 11:50 AM
dcjcdc's Avatar
thanks for the responses...
bought an after market from canadain atire
was easier than i thought..
remove the boot cover ..remove spring and disconnect bulb and vice versa..thanks
Volvo940
Dec 11, 2007 11:09 AM
PASnow
Apr 19, 2007 09:53 PM
Swedishmeatballs
Jan 6, 2007 12:46 PM
robert213
Dec 11, 2005 03:09 AM
jlorgan
Jun 30, 2005 06:06 PM
