2002 V70 T5 Wagon New Fuel Pump
Old Aug 8, 2020 | 07:41 AM
j&w2002V70's Avatar
Default 2002 V70 T5 Wagon New Fuel Pump
After checking all relays determined that the fuel pump was bad. Disconnected the battery first, removed the rear seats, and then replaced the pump. Decided to reconnect the battery and test the pump before I put the rear seats in which I then had fuel pressure at the fuel rail. Before all above was done the engine used to turn over using starting either. Now have the fuel pressure but even using the starting either engine wont turn over. Question is with the rear seats not installed and the rear airbags disconnected is there some sort of safety over ride that prevents ignition spark?
Old Aug 8, 2020 | 09:41 AM
No...
Old Aug 9, 2020 | 09:14 AM
j&w2002V70's Avatar
Just don't understand why the engine would run with starting either before installing new fuel pump and now with new pump and fuel pressure at the fuel rail and using starting either will not run!
brianb
Dec 6, 2021 02:43 PM
cordobe
Dec 1, 2014 06:47 PM
Scooter1986
1998-2000 model year V70
Oct 30, 2013 01:21 PM
fjbrown
Apr 29, 2011 04:58 PM
miwilker
Dec 19, 2009 07:25 AM
