2005 s40 air conditioning
Old Aug 4, 2019 | 04:10 PM
linzk's Avatar
Default 2005 s40 air conditioning
Was running fine and one day it just went hot in an instant. Checked refrigerant and gauge says mechanical problems
Old Aug 4, 2019 | 07:30 PM
well not sure how a gauge can tell you there are mechanical problem. Do you hear/see the compressor kicking on? Did you check fuses/relays? Any blinking lights in the REC and AC buttons (which flash when the climate control computer senses a fault). Best to also take a look at the serpentine belt as well just in case...
Old Aug 7, 2019 | 04:06 PM
ROYAL-MILES's Avatar
Does it stay cool for the first few minutes when you turn it on and then goes hot? if yes it could be a problem with the clutch which needs replacement/re-shimming. I had a problem with my 2005 S40 which cooled for 5-10 mins and then stopped which i solved by sticking bread clips in the clutch (Have to do it the proper way by getting the clutch off but its been working since two months so i am not too worried especially with the winter approaching i wont be needing cool air). If it stays hot from the start it could be something else.
pjvolvo
Jul 20, 2015 03:28 PM
pootyhead
Jul 11, 2013 07:29 AM
s40wit
Jan 18, 2013 01:29 AM
tnvolsvo
Jun 4, 2012 07:41 AM
Prospect62
May 27, 2010 07:47 PM
