'04 S40 2.4 Air Con stops working on hot days
Old Jan 16, 2013 | 01:12 PM
s40wit's Avatar
Default '04 S40 2.4 Air Con stops working on hot days
Hi All
First post here.
My S40 2.4 Auto has an issue in that the AC will stop cooling the car, particularly on hot days when its most needed. It comes on for short periods and then it works 100% but for some reason it does not work all the time.
The fans are running, air comes out the vents but its not cool. Its as if something prevents the AC compressor from running clutching in.
Any suggestions?
Old Jan 16, 2013 | 06:42 PM
Hudini's Avatar
Try this. It worked for my 2005 T5. Did not have to remove the compressor either.
https://volvoforums.com/forum/volvo-...shimming-6665/
Old Jan 17, 2013 | 05:37 AM
s40wit's Avatar
Thanks for the reply.
Do you think its the clutch even though the AC works well (perfect) in cooler weather?
Old Jan 17, 2013 | 06:32 PM
Hudini's Avatar
Yes. You describe the classic symptoms. When the compressor is working the hardest it suddenly stops and you get warm air. When it cools a tiny bit it starts working again. The deshimming procedure simply removes one small shim (of 3 total) which moves the clutch closer to the compressor.
Old Jan 18, 2013 | 01:29 AM
s40wit's Avatar
Thanks Hudini, I will try this. Can always put it back if no improvement. Also, its a no-cost exercise.
NickF
Aug 15, 2012 09:04 AM
Daddy Z
Nov 10, 2010 05:50 PM
outblast
Jan 1, 2008 01:52 PM
beardo265
Sep 27, 2007 09:24 AM
