2006 Volvo V70 driver side low beam out
Old Jan 14, 2024 | 05:59 PM
Mason2801's Avatar
Default 2006 Volvo V70 driver side low beam out
I needs some help. I have a 2006 V70. I have a low beam out on the driver's side. It went out and I replaced it. A few weeks later it went out again this time the socket it plugs into was burnt. So I replaced it. Now I have no power to it. I checked the fuse. It was fine. I am at a loss
Old Jan 14, 2024 | 10:05 PM
In some Volvos - if the CEM thinks there is a short to a bulb - A code will be set, and will not send power until the code is read and erased. Think of it as a circuit breaker, and the only way to reset it - is to read and erase the code in the CEM.
Old Jan 15, 2024 | 04:33 AM
Mason2801's Avatar
Default CEM Reset
How do I reset the CEM? Do I plug in withy code reader and erase the code? I really appreciate your response and help with this. I know if I took it to a shop they would charge me a huge amount. I took it in to have them look at a taillight and they wanted over $400 to fix it. I declined and replaced the upper taillight assembly for $75 from eBay.
Old Jan 15, 2024 | 08:21 AM
1. How do I reset the CEM?
2. I declined and replaced the upper taillight assembly for $75 from eBay.
1. Use a compatible scan tool to read and erase codes in the CEM
2. There's always a cheaper way
Old Jan 15, 2024 | 02:13 PM
Mason2801's Avatar
Default A cheaper way?
I seen a cheaper way. I am all ears. Please tell me if there is an easier way to do this.
Old May 31, 2025 | 12:39 PM
ernna44's Avatar
PugNug
Oct 24, 2021 01:52 PM
sunstar
Sep 6, 2021 06:46 PM
SleepyD
Nov 30, 2019 02:06 PM
Doldrums
Dec 29, 2017 03:55 PM
Chris Mayes
Aug 23, 2017 01:51 PM
