94 850 turbo airconditing problem
Old Jun 27, 2005 | 09:52 PM
Muddy Footer's Avatar
Default 94 850 turbo airconditing problem
First time Volvo owner, I had the airconditing recharged a couple of weeks ago, it was working ok, cool but not frezing. It would work fine when you first start out, if you dont stop for gas or for some other reason. I was told it is a inside temp unit, if so can i temporally by-pass this unit or should I replace it, and where is it.
Old Jun 27, 2005 | 09:53 PM
Default RE: 94 850 turbo airconditing problem
You might have a leak or a bad compressor.
It kind of sounds like a bad compressor.
Old Jun 27, 2005 | 09:59 PM
Default RE: 94 850 turbo cruse control problem.
Having cruse control problems, it works when it wants to, If I set the cruse and its working fine untill I apply the brake, some times I can just resume other times I have to touch set, and today it wouldnt work after I just got through using it.
Old Jun 27, 2005 | 10:11 PM
There is a possibility that the brake switch is out of adjustment.It might not sit in the switch properly all the time.
lukesvolvo
Oct 6, 2020 01:22 PM
Keith Tobberman
Sep 30, 2011 10:36 AM
BXS0D0B
Nov 16, 2005 08:40 PM
apineiro
Mar 28, 2005 02:43 PM
