850 Turbo problem
Old Nov 15, 2005 | 08:51 AM
BXS0D0B's Avatar
Default 850 Turbo problem
Im new to Volvo and just love this car. Problem is the part in the front grill, which connects to the turbo piping, has come dissattatched. I noticed this, and strated putting it back on, but the rubber-stretching pins broke. Its attatched now, but barely. What should i do? Is this expensive, bad to drive?
Lastly, i've looked around a lot about the headlight wiper problem, and have had a hard time finding the right info. Are the ones i posted below the standard, and are they easily fixable. thank you,
Old Nov 15, 2005 | 08:43 PM
Default RE: 850 Turbo problem
Did the intercooler or the hose break.
What are you trying to find out about the headlight wipers?
Old Nov 16, 2005 | 03:46 AM
BXS0D0B's Avatar
The intercooler is the one that i have busted up. The hose seems completely intact and without any problems. I could not get the thing to attatch correctly with the rubber-stretch locks. I did get it attatched but its hanging buy a half broken rubber lock, and its sort of banged up, and in a little bit of a different position. This intercooler doesnt look very expensive, but i suppose the car could have major problems if this wasnt set correctly.
Sorry, i guess i didnt explain the wipers. The one on the passengers side is completely messed up. It rarely works, but most of the time it stays in an upward position--not resting. Those dials, that i see near the headlights, are impossible to move,....and im not sure if i should be trying that anyways. Drivers side works completely fine.
Thank you very much for you help,
Old Nov 16, 2005 | 08:40 PM
The pictures of the dials are for the Headlight Adjusting.
The wiper motor is under the headlight asselmbly.
If it had an air leak at the intercooler it would idle funny.
lukesvolvo
Oct 6, 2020 01:22 PM
Keith Tobberman
Sep 30, 2011 10:36 AM
Muddy Footer
Jun 27, 2005 10:11 PM
apineiro
Mar 28, 2005 02:43 PM
