ABS light is on
Old Jun 2, 2005 | 12:29 PM
levnay's Avatar
Default ABS light is on
Hello, I am a new member.
Appreciate any suggestions befor taking car to the shop.
I have VOLVO S70 1999. Last week ABS warning light has come on and since that
it stays steadily when engine is on.
thanks, lev
Old Jun 2, 2005 | 12:58 PM
Default RE: ABS light is on
Check out the ABS module they go bad very often.
Old Jun 2, 2005 | 05:39 PM
levnay's Avatar
Thanks, but I even do not know where ABS module is located.
Probably under the hood.
thanks any way, lev
Old Jun 2, 2005 | 08:26 PM
Look under the master cylinder and the resivior.You will see a pump motor under the master cylinder.Then down further you will see a black box bolted to the under side of the pump motor.The is the module you will need a special inverted torxes socket to get the screws out.
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
