Code P0342 No spark Help please
Old Nov 13, 2013 | 01:17 PM
Deaconfan423's Avatar
Unhappy Code P0342 No spark Help please
I am at a loss. Volvo S80, 1999 2.9l (non turbo). Message came up Low coolant, put a little coolant in it. Put on new rotors and brake pads and two days later the car cut off while driving and will not crank. I am almost positive that the coolant and pads have nothing to do with it.
I got code P0342 (CMP Sensor low) . I did a hard battery reset, checked fuses, replaced the plugs, replaced the CMP sensor, Crank shaft sensor with stillno luck. While installing and working on these I noticed two issues. The timing belt looked loose and the Engine Ground cable (31/44) was not connected to anything.
Is this much space normal in a timing belt? Where does this ground cable connect? What else should I check?
Old Nov 13, 2013 | 03:45 PM
well never mind, Dont know why I didnt check the timing belt sooner, but it was broken. I hope i didnt do damage
Old Nov 15, 2013 | 10:29 PM
graham7773's Avatar
Default timing belt, ground/earth cable
Re the timing belt, the engine is probably damaged, bent valves etc. Large repair. Re the ground/earth cable, it should be bolted to your engine. If it is bolted to your engine and flapping loose, bolt it to a good earth point on the body. I am also a newbie on these forums but at 71 years of age have learned a thing or two about cars.
ceepyou
Mar 9, 2012 11:50 AM
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
joker834
Nov 15, 2006 10:15 PM
