Electrical fault on my old Volvo V70
Old Aug 21, 2020 | 07:36 AM
PhilBut's Avatar
Default Electrical fault on my old Volvo V70
Hello all. I`m a new member. My name is Phil. I`ve had my Volvo V70 for 8 years now. 53 plate. 270,000 miles. Love the car. But the last couple of years , when the car gets hot, as in after an hours driving I start to get stuff coming on dashboard ie: left rear door open. 5 minutes later I get Brake failure signal. It goes off when I switch the ignition on and off but it carries on until the car has completely cooled down. I just need some ideas of what it could be because if I take it to a garage it will be difficult to find the problem. I do have a Volvo specialist within 5 miles of where I live but it`s still a case of time and money.
I would appreciate any input.
Regards Phil
Old Aug 21, 2020 | 03:13 PM
Could be a relay overheating. Check a wiring diagram/fuse layout to see which circuits may be common to your fault codes.
Old Aug 21, 2020 | 03:25 PM
PhilBut's Avatar
Thanks for that. I will check it out.
Old Aug 21, 2020 | 04:09 PM
What year? If it's a 01-04 you might have an overheating CEM. Check what xemodex says are symptoms, how to test it, and their solution at this link - https://xemodex.com/us/product/centr...0657629-00-22/
Old Aug 21, 2020 | 04:20 PM
PhilBut's Avatar
Thanks for that. Interesting stuff. I will look at that
Old Aug 22, 2020 | 11:17 AM
PhilBut's Avatar
Thank you. Makes sense. I'll do a bit of research on the subject
Old Aug 22, 2020 | 11:18 AM
PhilBut's Avatar
erikvolvoV70
1998-2000 model year V70
Jul 15, 2012 02:59 PM
malaka
May 23, 2010 07:11 PM
HummerGuy
Jun 26, 2008 09:52 AM
8arlie8
May 9, 2008 04:43 PM
turbodesigner
Mar 19, 2004 12:59 PM
