Help !!!!!!!
Old Dec 8, 2020 | 03:17 PM
Lester Schunk's Avatar
Default Help !!!!!!!
Have a 2006 Volvo S40 2.4. Have just replaced the 5 spark plugs,5 ignition coil, all 3 of the Oxygen Sensors and just replaced the MAF Sensor. The car hesitates and runs horribly. Burns a lot of gas. The "Shift Up or Shift Down" warning light comes on with the purple Diamond also. What am I missing???? The car stiff runs terrible !!! HELP!!!!!!!
Old Dec 8, 2020 | 04:22 PM
Originally Posted by Lester Schunk
replaced 5 spark plugs,5 ignition coil, all 3 of the Oxygen Sensors and just replaced the MAF Sensor.
#1 - BEFORE you replace parts -
SCAN the car with an appropriate scan tool - you might get a code that will point you (or someone who actually fixes cars instead of replacing parts on a guess) in the right direction toward solving your problem.
What codes are stored?
Old Dec 8, 2020 | 04:48 PM
P0304 and P0172
Old Dec 8, 2020 | 05:08 PM
P0304 and P0172
304 is a miss-fire on x cylinder - can you isolate the cylinder? Unplug the injectors one at a time. Which injector makes the idle change the least or the worst? What's the compression?
172 is a rich code - What's the fuel pressure? Does the fuel pressure reading on your scan tool (if yours gives you live data) match your analog gauge you attached? Perhaps the fuel pressure sensor is making the pump run too much - (bit not likely)
It would be unusual but not unheard of that an injector is leaking and causing both the miss-fire and the rich condition.
cdattilo1
Sep 10, 2020 03:59 PM
rocketarm09
Apr 7, 2012 02:33 PM
gomer
Aug 10, 2011 07:31 PM
tinny
Apr 12, 2011 11:00 AM
v40 blue
Apr 27, 2007 01:10 AM
