low compression
Old May 7, 2013 | 02:42 PM
lilredcamaros's Avatar
Question low compression
Hi I have a 97 850 and I developed a misfire in my #5 cylinder I did a compression check and it went to 40psi and that was it,but,the weird part is is that it held at that # for almost an hr till I released the pressure can anyone give me some advice on what the cause could be.
Old May 7, 2013 | 11:08 PM
ES6T's Avatar
A compression gauge has a check valve so it will hold pressure indefinitely. It just measures peak compression. You need to do a cylinder leakage test to find where the leakage is.
Old May 8, 2013 | 01:54 AM
Ok how hard is this and what do I need to accomplish this.
Old May 8, 2013 | 05:28 AM
ES6T's Avatar
You need a compressor and a cylinder leakage test gauge set which should come with instructions. You pressurize the cylinder at TDC compression and listen for where the air escapes.
david1
Apr 29, 2009 09:08 PM
rainier34
Jan 29, 2008 05:50 PM
melymel
Oct 6, 2007 08:53 AM
melymel
Oct 5, 2007 10:40 AM
bnuk013
Nov 2, 2006 10:12 PM
