Radio problem
Old May 9, 2017 | 08:53 PM
mrayk's Avatar
Default Radio problem
1997 Volvo 850. I received a code number for my radio reset based on my vin YV1LS5551V1355537 Code (3256 ) didn't reset. can I get a code number from my radio info ? Ser # VO7100H4044057 E model 710 Secondary number 3533433-1,
Thank you Mike
Old May 9, 2017 | 10:24 PM
if you got the code that didn't work from a dealer based on your VIN then its likely somebody swapped out the radio. Did you pull the radio out via the two end tabs to see if the code is written on the body of the radio? PS - not much point to the security system if you could simply get the code from the radio's serial number... but hey its worth asking. If you feel the radio is the original, then you may want to double check the glove box or owner manual for the little card or sometimes people write the code into the book
premiummotor
Jan 1, 2016 12:46 PM
cbgav
Sep 10, 2007 05:25 PM
PeterS
Dec 1, 2004 06:12 PM
