Worn Rotors - Repair vs. Replace
Old Jun 13, 2014 | 02:41 AM
Chuck_S80's Avatar
Default Worn Rotors - Repair vs. Replace
I've got what seems like should be a normal problem for an older car like mine and I wanted to ask for some advice on how to possibly fix it.
After 125 K miles, the front brake rotors on my car (details below) have been worn through normal contact with the pads. Because the pads don't contact the entire surface of the disc, the center portion of the disc has worn away slightly and left slightly higher ridge (about 2mm) around the edge of the disc. So, although my pads have 4mm remaining only 2mm is really useful - because the ridge is higher than the worn surface, the rotor will contact the the "wear tab" on the pad earlier than it would on a new, unworn disc.
My mechanic recommends replacing the rotors but I once took a pair of warped rotors to Pep Boys and they machined them true for about $40. Is there any reason why a similar solution can't be used to remove the ridge from my old rotors and save me $400 too?
Make: Volvo
Model: S80
Year: 2001
Mileage: 125,000
Old Jun 13, 2014 | 03:21 AM
damien360's Avatar
Sounds like the rotor are already below minimum specifications and cannot be machined down. So your only solution is to replace them.
Old Jun 13, 2014 | 06:38 AM
ES6T's Avatar
Damien is right. There are minimum thickness specs for machining and I would bet you are below them. You could buy a rotor micrometer to check if you want.
Old Jun 13, 2014 | 07:13 AM
pkrface's Avatar
Personally I never resurface rotors. Past experience tells me the reduced thickness, even within spec, results is very easy warping and then I am unhappy with the performance. Aftermarket rotors are almost always cheap enough (<$60 at IPD for my S60) that putting new on really doesn't add that much cost and it saves the time of taking them somewhere to get turned. Add in the possibility of getting some doof who doesn't really know what he is doing running the machine adds another plus to the replacement side.
Old Jun 13, 2014 | 11:10 AM
migbro's Avatar
At 125K your rotors don't owe you anything. Buy new but only Volvo parts or equivalent quality. Don't get sucked into slotted or drilled rotors as they offer no benefit for street vehicles.
Also, the secret to a great brake job with new rotors is to clean the mating surface of the hub to shiny metal with a wire wheel on an angle grinder. That way the new rotor runs true.
Old Jun 16, 2014 | 11:09 AM
jks2's Avatar
Volvo does not recommend turning rotors. They get too thin and then will warp. Spring for some new ones.
Old Jun 18, 2014 | 12:02 PM
Chuck_S80's Avatar
Default Thanks everbody!
Thanks for your opinions, folks. I decided not to follow my initial cheapskate impulse and replaced the rotors with Volvo parts.
Old Jun 18, 2014 | 08:20 PM
spoker's Avatar
That would be the best and safest way to repair it. By the way welcome to the forums.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
ccoaston
Apr 2, 2015 07:58 AM
8T9GTA
Nov 24, 2007 09:10 PM
AaronD81
Interior
Mar 12, 2007 01:40 PM
