2.4 and 2.5 light pressure turbos
hi, I've been looking around the net for relatively current (2000+) volvo turbo specs and have got no luck. But I'm sure you guys can tell me this:
I need a light pressure turbo that'll hold boost till redline with a little head room for when I get the block built for a 2.4L honda motor. What are the current 2.4L and 2.5L turbo's and what model can I rip one out of? Also info on water and/or oil cooled, ball bearing, if it's cast into the exhaust manifold, flange shape, price... etc would be greatly appreciate. Pretty much any information you can tell me would be excellent.
Thanks in advance
Thanks in advance
RE: 2.4 and 2.5 light pressure turbos
The current LPT turbos are at 13g which is found on the 1999 s70 awd models, also on most if not all of the 99+ awd models Volvo offers. As for it holding boost till redline, I doubt it will.
You will want to go with an HPT turbo like a 16T. Which isn't much bigger then a 15g, but the 16T flows better.
