i thought turbos made cars faster
Old Jun 21, 2006 | 01:07 AM
charlie brown's Avatar
Default i thought turbos made cars faster
yeah i have a 89 760 turbo with 114000 miles on it that i just bought it runs but very under powered it did some checking and found that the turbo wastegate rod was disconnected , so when i reconnected and drove the engine would not rev over 2500 it missed and black smoke was coming out of the exhaust, it also sounds like you can here the boost coming out somewhere, i replaced the vacuum lines, the hose from the mass air flow sensor to the turbo, removed the catalytic converter, all to no avail, any help would be appreciated
Old Jun 21, 2006 | 01:39 AM
Default RE: i thought turbos made cars faster
Make sure the rest of the hoses are good.
Something is making it run way to Rich.
Black smoke means running rich.
Plugs
Wires
Injectors
Mass flow sensor
O2 sensor
They could all make it run like that.
Old Jun 22, 2006 | 12:19 AM
ive checked all the hoses and theres no code or ses lamps on the only time i have this problem is when the turbo wastegate rod is hooked up, other than that it runs as good as a four cylinder in a car that big will run, the wires plugs and o2 sensor are new also
Old Jun 22, 2006 | 12:58 AM
Maybe wrong computer in the car.
CrusherCurtis
Nov 28, 2008 05:43 PM
Cappachinoo
Jun 18, 2007 12:55 PM
s60r2007
May 18, 2007 04:17 PM
green940turbobrick
Nov 15, 2006 01:55 AM
cool_kyle_3000
Oct 18, 2005 07:31 PM
