North East ME, NH, VT, MA, RI, CT, NJ, NY, PA
engine running rough.....
Old Aug 16, 2010 | 12:41 PM
guysmilee's Avatar
Default engine running rough.....
Spitting and sputtering, changed fuel filter and air filter. Two cans of injector cleaner later it seemed to work itself out. 400 miles later I am back to the same problem. Pretty sure its a sensor but am unsure where to start, any help would be greatly appreciated.
Old Aug 16, 2010 | 12:43 PM
guysmilee's Avatar
This is a 1987 740 Turbo
Old Aug 18, 2010 | 09:48 PM
blitzed's Avatar
Its either a Mass air flow sensor issue or a fuel pump is not keeping up the flow and causing it to run rough...I had a 740 regina system and it was running rough and missing etc...ended up being the fuel pump was flowing enough to keep the car running at idle, but give it gas and it would stumble and run crappy. Changed the fuel pump, and ran like a champ
Old Aug 29, 2010 | 08:24 PM
titaniums6025t's Avatar
could also be a stuck egr valve or loose intercooler connection... my 2 cents.
tina2222
Nov 15, 2014 10:06 PM
garysvolvo
Aug 14, 2012 04:21 PM
tjohnson05
Mar 23, 2010 09:32 PM
Carbuff
Nov 29, 2005 09:30 PM
duffdr
Apr 12, 2005 01:51 AM
