engine is running rough on model s30
Old Nov 15, 2014 | 07:09 PM
tina2222's Avatar
Question engine is running rough on model s30
My car feels like it wants to stall and it is much louder than normal. the check engine light is on. A friend of mine changed the spark plugs for me. He said that the 6th spark plug has oil around it. I don't understand what that means. He also said that I should buy a valve cover gasket kit. I was reading some remarks and they said that's not a good idea and some said that their is none on my model. Can someone please give me advice. It would be much appreciated.
Old Nov 15, 2014 | 08:35 PM
damien360's Avatar
Well your car doesn't exactly have a gasket. It's an anaerobic sealant that is applied between the head and the cam cover. A lot of times the pcv is plugged causing oil to come out of the oil filter cap
Old Nov 15, 2014 | 09:19 PM
tina2222's Avatar
Default rough running engine
Thanks. So if he unplugs it will it run better?should he apply sealant as well?damien360;400162]Well your car doesn't exactly have a gasket. It's an anaerobic sealant that is applied between the head and the cam cover. A lot of times the pc sudden is plugged causing oil to come out of the oil filter cap[/QUOTE]
Old Nov 15, 2014 | 09:42 PM
damien360's Avatar
No the pcv system needs to be serviced. I recommend replacing all parts instead of cleanign them to ensure it is the cleanest possible.
Old Nov 15, 2014 | 10:06 PM
tina2222's Avatar
What is the pcv system? Do you know how much it will cost? I'm sorry if I sound stupid but I really am trying to figure it out. Do you think it is a big job to do?
garysvolvo
Aug 14, 2012 04:21 PM
guysmilee
North East
Aug 29, 2010 08:24 PM
tjohnson05
Mar 23, 2010 09:32 PM
Clutch/B5audi
Nov 6, 2006 04:55 PM
duffdr
Apr 12, 2005 01:51 AM
