need some help please. :-)
Old Apr 27, 2009 | 08:44 PM
oldervolvo's Avatar
Thumbs up need some help please. :-)
I would like to buy a OBD Scanner for a 94 850 turbo volvo......
where can I get one.
Old Apr 28, 2009 | 09:57 AM
TIPSP's Avatar
Got Boost?
http://www.ipdusa.com/Universal-Prod...-202-627-1296/
Old Apr 28, 2009 | 10:43 AM
01_fast_ride's Avatar
The Scan Gauge or any other OBD2 scanner won't do. They only work on cars 96 or newer. Prior to 96 car manufacturers each had their own proprietary diagnostic port.
I thought that the 850s had their own OnBoard Diagnostics. Something like an LED that would flash in sequence. If you do a search in the 850 forum, I am sure you will find where to find it and how to read codes.
Old Apr 28, 2009 | 11:04 AM
TIPSP's Avatar
Got Boost?
http://www.troublecodes.net/Volvo/
Old Apr 28, 2009 | 06:08 PM
oldervolvo's Avatar
Thank you guy much.......
I went to the sight TISP and it is for 89-93 models (and later non-turbo/non-OBDII models)
94 and later models with OBDII
The 850 turbo and 960 models are OBD II system which are only accessible with a scanner..
I need to know now how I can tell if my system is OBDII or not
It is a 94 850 Turbo.
Thanks
Old Apr 28, 2009 | 07:15 PM
TIPSP's Avatar
Got Boost?
oldervolvo....check by your ECU... there still might be the stock black obd box.....
Old Apr 28, 2009 | 07:36 PM
The 94 should be both but the OBDII you can only read engine codes. But not all 94's have OBDII plugs in the car.
Old Apr 29, 2009 | 05:26 PM
oldervolvo's Avatar
Thank you.....I found the OBDII right abouve the gear shift......now need to get me one that will work for/with a 850 volvo :-)
Old Apr 29, 2009 | 06:17 PM
TIPSP's Avatar
Got Boost?
oldervolvo....
You might also have the OBD 1 port in the engine....
Look for this:
Old Apr 29, 2009 | 11:19 PM
I picked up a OBD-II scanner from eBay. It has worked great for me so far. I have a '95 850, SEE BELOW.
It was shipped from China and was pretty cheep.
Old Apr 30, 2009 | 06:25 PM
oldervolvo's Avatar
yes....I do have an OBD-I TISP......THANKS FOR THE HELP......NOW I WILL PULL THE CODES IN THE MORN AND SEE WHAT IS WRONG
Lansdowne
Sep 22, 2014 01:02 AM
jderosa3
Mar 20, 2011 03:01 PM
Sanel30
Feb 18, 2010 09:16 PM
eshghehBMW
Nov 19, 2007 04:28 PM
B1mmer
Dec 18, 2006 11:24 PM
