Penta Discuss Volvo Penta Marine Machines Within.
4.3 GL Draining Question
Old Oct 17, 2021 | 02:22 PM
jgrant's Avatar
Default 4.3 GL Draining Question
I have a 2006 4.3 GL-E engine which I'm winterizing for the first time.
I did not have access to a hose, so did not use the engine flush connector to run water through the engine for 5 minutes to "ensure drain ports are open".
What are these "drain ports"?
Also, the shop manual instructions (attached) I have says CAUTION ...
"If a garden hose with fresh water supply is unavailable,
you must remove the hose nipple(s) from the engine to
drain the engine block. To ensure all water is drained,
clear the drain hole with a piece of wire. After the engine is
drained reinstall the hose nipples and flush adapter as
removed. The exhaust manifolds are drained as described
previously"
What hose nipples are they telling me to remove?
Any help would be much appreciated!
File Type: pdf
Old Nov 14, 2021 | 08:12 PM
DTD's Avatar
DTD
Default 4.3 GL draining the block
The drain plugs are on the bottom of the block just above where the oil pan is attached. You can feel them. Typically drain plugs, but sometimes people have put a small valve to replace the drain plugs
Sometimes a chunk of rust from the cast iron block gets clogged around the drain hole thus why they suggest one to poke a small screwdriver or nail into the hole to clear the chunk of rust and allow all the water in the block to drain.
Lakeman
Penta
Sep 27, 2019 09:40 PM
240-FAN
Jul 20, 2018 06:26 PM
nomadly
Apr 9, 2008 05:37 PM
Beardog
Sep 5, 2007 05:15 AM
Volvo2001
Aug 24, 2006 09:52 PM
