Unknown Hose on my Transmission. . .
Old Aug 24, 2006 | 07:28 PM
Volvo2001's Avatar
Default Unknown Hose on my Transmission. . .
Can anyone tell me what this is? I have a 2001 S60.
It's next to the Gear Shift Position Sensor
Old Aug 24, 2006 | 08:41 PM
Default RE: Unknown Hose on my Transmission. . .
It is a Vent hose.
Old Aug 24, 2006 | 09:02 PM
Volvo2001's Avatar
Thank you oh Most Knowledable!!
Your the first person who could answer the question. [sm=groupwave.gif]
I tried other forums and no one knew.
NOW, for a better question.
If I want to flush the transmission, where to I connect the drain hose to?
Old Aug 24, 2006 | 09:41 PM
On the S60 I believe the Hose is the upper Trans. cooler line.
Hook a hose up and run it into a Drain pail or soemthing like that.
Use a clear hose and watch for Bubbles.Then turn it off and Add 2 Quarts then start it again and watch for the same thing. Do that till you run all the fluid you want through or it all comes out red.
Old Aug 24, 2006 | 09:52 PM
Volvo2001's Avatar
Mucho Thanks!! [sm=thanx.gif]
97black850
Aug 4, 2013 12:35 PM
jsenge
Jan 18, 2008 02:51 PM
alzdream
Jan 11, 2008 06:35 PM
J Telectro
Aug 17, 2007 05:48 AM
paul_con
Mar 14, 2007 05:33 PM
