Penta Discuss Volvo Penta Marine Machines Within.
AD41B high coolant pressure
Old Apr 22, 2025 | 06:54 AM
randyroose's Avatar
Default AD41B high coolant pressure
My AD41B was overheating so I replaced the thermostats and took it for a test drive. Shortly after leaving the marina, the large cooling water pipe came out of the heat exchanger and shot coolant everywhere. Got it back to the dock and did a pressure check on the cooling system. Running at idle, within a minute, the pressure climbs up to 20 PSI. No wonder the pipe blew out. I think I have a blown head gasket.
Does anyone think that the turbocharger could be causing the high coolant pressure problem? I bought a cheap Chinese one and it only has a few hours on it.
I am going to pull the injectors out and do a compression check on each cylinder. I have a spare set of copper injector sleeves so I will pull all of them out as well. Maybe one of them is leaking. Hopefully I can find something wrong and not have to pull the head and change the gasket.
Any suggestions with this would be greatly appreciated!
Slibo
Mar 11, 2022 02:24 PM
dericksonpe
Jul 26, 2020 12:29 PM
Crispin
Nov 20, 2014 11:11 AM
JimKW
Oct 4, 2011 10:44 PM
91740Turbo
Jul 4, 2011 08:28 AM
