Penta Discuss Volvo Penta Marine Machines Within.
DPS-B drive Trim Won't Stay Up Under Load
Old Jun 28, 2022 | 10:07 PM
csstober's Avatar
Default DPS-B drive Trim Won't Stay Up Under Load
I have a 2015 Chaparral 270 Signature with the DPS -B outdrive. The drive won't stay trimmed up while on plane. It will go up but drops back down within a few seconds while under load. The drive will stay up indefinitely while on trailer or sitting in the water. I have replaced the trim pump as we suspected that the check valve within had gone bad allowing fluid to flow back into pump while under load. Drive is still falling even with new trim pump installed. I don't see any oil sheen on water indicating a leaking trim cylinder. Any suggestions on where to look next or how to test the cylinders? Thanks in advance!
Old Jun 29, 2022 | 03:56 AM
DTD's Avatar
DTD
Default Trim cylinder
I suspect it's leaking between the top section and bottom section of one or both trim cylinders. Hopefully you can get a trim cylinder seal kit and install it. Look for any damaged or corroded parts that would prevent a good seal. The trim pump pushes trim fluid to the top of the cylinder or to the bottom. The trim pump motor and go in either direction to pump.
dmedalie
Interior
Oct 6, 2009 01:32 PM
83242GT
Jun 29, 2008 12:36 AM
apollo
Penta
Feb 16, 2008 07:55 PM
leep
Penta
Jun 21, 2007 12:50 AM
Bonz145
Penta
Apr 14, 2007 11:35 AM
