What did you do to your car today?
Old May 14, 2017 | 06:26 PM
  #1181
Dan Knieriemen's Avatar
Default 1992 volvo 240
I need some help with my car, every time i slow down i get this vicious vibrating and shaking under my car whrn I go under 20 mph to brake any ideas of what it could be om stuck
Old May 14, 2017 | 11:16 PM
  #1182
Volvo_Runs_On_Grass's Avatar
Some times when replacing the rotors some hardware gets forgotten, And even a silly bolt that helps along the rim , also helps with the proper balance of the wheel, maybe I'm over thinking it and you should rotate all tires and see if it continues
Old Aug 16, 2017 | 02:35 AM
  #1183
petrik's Avatar
Default What I did Today
I've had my V50 T5 for 3 weeks now and well today i did the the following
- TCV replacement
- Upgrade of vacuum hoses to silicon
Then had to do the following as a result of snapping the hose nipple in the inlet manifold
- Remove and clean airbox and intake
- Sparkplug change seeing as everything had to come off
- Clean of the throttle body
- Clean of the intake
- Refix nipple to the intake
- Degrease the skid plate and underbody ( was pretty tidy )
Getting the airbox out is a pain and I have promised myself to change intake system at some stage even though it probably wont make a difference, just the future ease of working on the car would be worth.
Already completed
- Oil and filter change to full syn
- Radio and dash language change ( Jap import in NZ )
- Full diagnostics scan for any error codes ( none )
- Cabin air filter change ( PIA for RHD )
And to come as funds permit
- Intercooler upgrade
- Charged air system upgrade
- Intake upgrade
- CBV upgrade
- Wastegate upgrade
- Downpipe change
- Exhaust change
- Custom tune once all is in ( ARD, RiCA or similar )
Cheers have a good one
Old Nov 27, 2017 | 07:46 AM
  #1184
JackJ411's Avatar
I have a son who will soon be 16, and I want to buy volvo xc90 2011. I have a 2009 volvo xc30 but for kids all the best is how do you think I'll make the right decision about buying such a car to him? . What types of insurance policies exist for minors and how does it work?Or can give it to me and pick me up a new one Thank you
Old Dec 19, 2017 | 07:38 PM
  #1185
Disco2's Avatar
Converted my S80 to E85
Old Feb 19, 2018 | 10:56 PM
  #1186
GWSmith's Avatar
I just got my used 06 S40 2.4i today, lol, it looked pristine but I pulled down the rear seat console and reached behind it to find where the PO’s kids were stuffing their used retainer rubber bands 😂
Old Feb 23, 2018 | 10:56 AM
  #1187
GWSmith's Avatar
Default Headlight lens (semi)restoration
While it didn’t take all of the oxidation off, considering that all I did was worked a small amount on with a sponge then buffed it out, it did alright 👍
Old Feb 24, 2018 | 01:18 PM
  #1188
Sir Vivor's Avatar
Wha?
Swapped a (busted) headlight out for a new one recently, and the broken shards gave me a clue the headlight was made of GLASS.
Oxidation on plastic lenses... yes.
Oxidation on glass? Not so much.
Can it be that Volvo bestows glass on only select models?
Old Feb 24, 2018 | 02:48 PM
  #1189
GWSmith's Avatar
That’s possible, or these could be aftermarket I don’t know.
Old Feb 25, 2018 | 06:25 AM
  #1190
CRamsey's Avatar
New guy here... I bought my 2007 V50 about a month ago, been fixing little things since then. Had a major service done at 120,000 miles, belts and hoses replaced and good to go for a while.
Today:
replaced low beam bulbs and cleaned headlight projector lens, much better now.
replaced rear sway bar links, rides better and no more clunking sound in the turns.
replaced the auto shifter blind. It looks better and I now have use of the M+/- function.
changed oil and filter.
i still have some less critical items on the 120,000 service to complete. I can say that I’m pretty happy with my V50.
Old Feb 25, 2018 | 11:26 AM
  #1191
GWSmith's Avatar
Originally Posted by cramsey
new guy here... I bought my 2007 v50 about a month ago, been fixing little things since then. Had a major service done at 120,000 miles, belts and hoses replaced and good to go for a while.
Today:
Replaced low beam bulbs and cleaned headlight projector lens, much better now.
Replaced rear sway bar links, rides better and no more clunking sound in the turns.
Replaced the auto shifter blind. It looks better and i now have use of the m+/- function.
Changed oil and filter.
I still have some less critical items on the 120,000 service to complete. I can say that i’m pretty happy with my v50.
Old Mar 28, 2018 | 11:01 PM
  #1192
dencrowd's Avatar
I'm just looking for a new insurance policy. Do you know what are the best parameters to choose car insurance? Some sites, like general insurance, provide lists of such companies but who can prove if they are true-to-life?
Old Apr 28, 2018 | 07:49 AM
  #1193
Georgeandkira's Avatar
Default old question
I just saw this post this minute (April 24, 2018).
All I can offer is that Liberty Mutual sent me a check instantly when I had a claim years ago.
Not real data, I know. G&K
Old May 13, 2018 | 10:20 PM
  #1194
bne's Avatar
bne
Default Swapped out frumpy 960 rims for 850 turbo wheels ;-)
Before...
After...
Old Jun 16, 2018 | 01:48 PM
  #1195
dytha99's Avatar
Default Finally got me a 745...
And drove it the 100 miles home.
Changed the oil... air filter... flame trap... stapled the headliner... washed it.
Interior in fairly typical for a 27 year old car but it's got low miles...221k. And the body is in good shape. No rusted out floorboards like my 244. Its a good neighbor my '89 744.
Much rather drive a box than a brick. Hubcaps have been switched out to oe Volvo caps.
Old Jan 28, 2019 | 06:57 AM
  #1196
pjsmithres's Avatar
Just drove it. This 2012 S60 is reliable and maintaining free other than oil changes and the new tires.
Old Jan 29, 2019 | 12:39 PM
  #1197
Sir Vivor's Avatar
Replaced the black plastic triangle panel that fits into the driver window. 2 of the 3 pins had busted (previous owners too rough).
Also expecting replacement shifter and emergent brake shrouds in the post. (Ebay has a good selection.)
I'd love to install a set of new rear door speakers (had to get baffles owing to door cavity leaking on speakers).
But I forgot the wiring polarity my installer set. Did he say the wire with writing was positive or negative?
He blows off emails and won't answer his damned phone!
Old Mar 22, 2019 | 11:01 AM
  #1198
thunderwagon's Avatar
Default Today I discovered new joys to diesel ownership
So today I did some electrical work under the hood, old wiring n such. I decided to do some load testing at start since my battery wasn't coming up to charge like it should. Rather, like someone who does not know diesels expects it should. This is my first foray into the land of the dieselasaurus and my ignorance far exceeds my knowledge. I discovered that my 70 amp hour battery that cost an arm is not enough to support daily driving for my D24 powered 240 wagon. My glow plugs draw over 60 amps slowly dropping as they heat up. Drive, stop, cool, start cycles over like 5 punch my battery directly in the nuts. The 88 amp hour battery I need costs an arm and a leg. It also weighs as much as I do. Yay for diesels!
Old Mar 23, 2019 | 10:59 AM
  #1199
Da Tow'd's Avatar
Replaced the 2 front wheel bearings and took off the studded winter tires and put the summer tires on.
checked the transmission fluid and added 1/2 L of ATF also a 1/2 L engine oil
Wife said it is a lot quieter with the new wheel bearings and no studs
happy wife happy life
cheers
Hank
Old Mar 23, 2019 | 04:38 PM
  #1200
Sir Vivor's Avatar
Just installed rear passenger door panel. Last couple of days had been drilling out holes into the oem speaker screen, after enlarging the hole to accommodate new speakers. Fortunately the screen is manufactured with half-way holes, so that drilling out new ones to the enlarged diameter is straightforward. But still no easy task owing to the shards that occlude holes until re-drilled, and re-re-drilled from both sides. Marked the larger diameter by applying lipstick to the speaker and pressing the door panel against that to mark where I needed to cut.
Upload/download photograph failed at 90% twice.
