Sights N Sounds Post all of your video and sound clips here.
Engine Rebuild (Timing Tensioner Bounce Issue) 2006 V70 2.5T
Old Jul 21, 2021 | 05:19 PM
Wombat Nips's Avatar
Question Engine Rebuild (Timing Tensioner Bounce Issue) 2006 V70 2.5T
Greetings,
I just finished a rebuild on my 2006 V70 2.5T after I bent a few valves from a timing belt snap on the highway. All the valves were replaced, lapped, new seals all around, full-timing belt kit including water pump. I start her up and she sounds great!
The issue comes when I go through a full visual inspection and I see that the timing belt tensioner (Temp Arm) is bouncing back and forth about 2-3 mm. I figure this is not normal and proceed to google the issue... and yes this is not normal. At this point, I have replaced the idler pulley and the tensioner arm and the issue is still present. I'm at a loss at this point.
Perhaps the engine just needs time to break in? More likely I am missing something... Any input is appreciated!!!!
-Wombi
91-740Turbo
Feb 3, 2019 11:06 AM
Dovydas
Aug 29, 2017 03:33 PM
patrm
2001-2013 model year V70
Feb 28, 2017 11:41 AM
placer61
Oct 6, 2015 12:16 PM
kclarke
Jun 29, 2015 10:54 AM
