Sights N Sounds Post all of your video and sound clips here.
Heat thermometer malfunction
Old Mar 31, 2018 | 06:56 AM
Omarkrmh's Avatar
Default Heat thermometer malfunction
Volvo xc90 heat thermometer does not go above the normal limit even if the motor is overheating. Caused me a lot of money cause i didn't realize my motor was overheating. Is there anyone that knows how to fix that? Thank you
Old Apr 8, 2018 | 06:29 PM
what year is your car? you can start by replacing the engine coolant temp sensor - the one under the thermostat. Then you can use a quality OBD2 reader to measure the temperature in place of the guage to see if all is normal. It will be hard to replicate an over temp condition. You may wind up needing to replace the gauge cluster if you think the guage is not reading.
V70XC1999INCT
Oct 14, 2008 01:04 PM
bahstunbob
Jul 17, 2008 08:02 PM
pcgold
Feb 27, 2007 11:58 AM
