Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
Whining power steering
Old May 5, 2014 | 08:52 PM
grrman13b's Avatar
Default Whining power steering
All; I have 2006 XC90, V8 & my power steering pump makes a hideous whining sound on first start with cold temp outside, once it warms up a bit it gets quieter until normal operating temp then no more noise. Has anyone else experienced this too? I will probably change the pump but what is the procedure for bleeding the system? Thanks in advance. Will
Old May 25, 2014 | 09:18 AM
John Arsenault's Avatar
You may have the wrong fluid in there. Volvo requires a special fluid and most people don't know that and use some conventional fluid and that leads to exactly what you describe.
Old Jun 2, 2014 | 05:29 PM
oragex's Avatar
Like above poster, many had the wrong fluid and the pump was noisy. Also inspect accessories belt.
merlinx
Dec 22, 2009 12:52 AM
cetaphil
Mar 23, 2009 08:27 PM
grahamk4y
Jan 22, 2008 08:56 PM
giacomozzi
Oct 20, 2005 09:34 PM
johnhon
May 22, 2005 09:55 AM
