‘84 245 Leaking on drivers side
Old Apr 22, 2024 | 04:26 PM
2brick's Avatar
Default ‘84 245 Leaking on drivers side
Hi all,
My 240 created a rather large puddle in the drivers footwell after a 40 minute drive. It is not from rainwater as it has not been out in the rain anytime recently. I had the A/C on pretty high the entire trip, and when I pulled into my driveway the puddle began to form. I also noticed that there was a lot of water draining from under the car (from 2 different spots..) Is my A/C drain clogged somewhere? If so how do I go about fixing it?
Old Apr 22, 2024 | 08:06 PM
The ac drain hose is accessible from the right side - remove the side panel on the console and it is visible - An s shaped hose from the bottom/center of the climate box that curves to the right side of the transmission tunnel. They certainly get clogged -
Old Apr 27, 2024 | 03:19 AM
dhsyu's Avatar
I've had a really good water release that tops off the driver's footwell, and I've at long last pinpointed it to coming from under the scramble close to the controlling segment. It dribbles onto the floormat. I've previously smothered the sunroof channels, so is there a typical region in the cowl that could cause this? I was pondering windshield fixing, however I'll actually look at under the wipers and cowl region first assuming something may be obstructed.
Kodi
ashgardner
Jun 3, 2025 03:50 PM
DumbVolvo
Jul 4, 2023 02:56 PM
Tcraven92
Feb 8, 2020 10:54 AM
kjurkic
Dec 24, 2015 07:32 PM
huzzsaba
Apr 23, 2007 07:57 PM
