Small puddle inside car during rainy day
Old Apr 13, 2007 | 09:47 PM
huzzsaba's Avatar
Default Small puddle inside car during rainy day
Its been raining all day today and i noticed a small puddle maybe 2 inces diameter on the passenger side front mat. Any idea to where its leaking from? Its not coolant for sure, its rain water.
Thanks!
Ali
Old Apr 14, 2007 | 01:10 AM
JPN's Avatar
JPN
Default RE: Small puddle inside car during rainy day
Hi Ali,
I would assume the leak is probably from poor windshield sealant, pax-side window weather strip, or the drain holes for the sunroof (if so equipped) may be plugged with dirt or one of the drain hoses may be disconnected.
Try dumping a bucket of water around those areas to see if you can reproduce the leak.
Good luck,
JPN
Old Apr 14, 2007 | 01:27 AM
huzzsaba's Avatar
I will try that.Thanks!
Old Apr 16, 2007 | 10:13 AM
BostonMike's Avatar
Hi guys,
Raining like crazy here in the Northeast US - i now have a swimming pool behind the drivers seat. I susptect the sunfoof. I checked the drains a couple months ago and they are clear. It is a 96 wagon, is gaskey deterioratio common? Is ita difficult job to replace?
Thanks,
Mike
Old Apr 16, 2007 | 11:02 AM
JPN's Avatar
JPN
Thereshould be4 drain holes for the sunroof, at each corner; the rearsmay notbe accessed without removing the interior trim (headliner). Try pouring water onto the drain rail to see if it drains onto the ground. If not, the holes may be blocked. Also, check the left rear window/door weather strips.
"Gasket" meaning the rubber piece on the roof glass? Unless physically damaged, it should be ok and the roof glass cannot seal out water completely; the reason why there are rain rails under the sides & front of the glass.
If the drain hose (s) is blocked or disconnected somehow, I would have it done at a dealer. If the rears are the problem, you may have to remove much of the interior trim pieces, and the sunroof assembly is very heavy, definitely a 2-men job.
JPN
Old Apr 23, 2007 | 10:16 AM
BostonMike's Avatar
Hey folks,
I found the leak that was drenching the interior of the car. Pulled down the headliner enogh to see the back of the sunroof, and sprayed the car. What I found was a small metal pin coming through the rear of the sunroof housing next to the drain line. It was dripping significantly. I took the easy, and I hope effective way our and completely sealed the area arounf the pin with Hot melt glue. All the drain lines are free and clear, but somehow water is pooling there when the car is paked on a slight hill.
next week - bolting the broken front door mount! gotta love these cars, they keep you busy!
Mike
Old Apr 23, 2007 | 07:57 PM
RedTurbo850's Avatar
^LoL, you got that right.
Seems like there's always something new to fix lol.
sicnarf
Jan 12, 2015 05:26 AM
jenninc
Mar 10, 2010 05:33 AM
malibu323538
Dec 28, 2008 10:07 PM
GeneAlexander
Nov 16, 2006 06:59 PM
insco2
Aug 30, 2006 01:22 PM
