‘92 240 no start
#21
(Turbos are non interference as well)...
If you get 0 compression, the pistons are not moving! There is no other explanation--no way you can have ALL cylinders equally damaged (bad valves, pistons with holes, belt missing or badly off, etc), to show no compression at all! You are missing something major somewhere...
#23
#25
#26
If the timing belt is in place, and the engine turns over when you crank it, then its impossible to have 0 PSI compression in all 4 cylinders. even with a severely blown head gasket, you'd have /some/ compression during cranking in some cylinders unless all 4 pistons were mechanically broken, and in that case it wouldn't turn over without making all kinda funky crunching sounds
know anyone with a borescope camera? inspect the piston crowns,
#27
#29
I had a Subaru that sheared the flex plate from the engine. The starter engaged, made a turning, whirling noise, but nothing else turned past the flex plate--sound might have been mistaken for engine turning. The "tech" who had worked on it before had over or under torqued the bolts and they sheared off... Never seen that before... engine had to come out.
#30
