1983 240DL Idle problem / throttle Problem
Old Dec 6, 2007 | 07:26 PM
toshields's Avatar
Default 1983 240DL Idle problem / throttle Problem
I have a 1983 240DL with a 4cyl w/167000 miles on it. it was running great with no problems then one day i was on the freeway and the car kept accerating out of control i put the car in neutral and it rev up really high so i shut it off and costed to the side i was right by my home so i had AAA tow it to my home. It starts and runs great but it revs like you have you foot on the floor. I have replaced The ECU, all vacume lines, cap, wires, it has a new battery i have owned the car for years and have had no problems with it at all, Except for the light switch breaking and i just replaced it. Does anyone have any suggestions What could be the problem?
Old Dec 6, 2007 | 08:03 PM
toshields's Avatar
Default RE: 1983 240DL Idle problem / throttle Problem
I also replaced the fuel injectors with in the last 500 miles.
Old Dec 7, 2007 | 01:19 AM
iamnickcarter's Avatar
throttle position sensor?
Old Dec 7, 2007 | 11:23 PM
83242GT's Avatar
sticking throttle linkage or throttle plate...clean them out really well and make sure the throttle cable isnt sticking
Old Dec 8, 2007 | 04:50 PM
funnyguy44444's Avatar
Check the see if the wire on the idle air motor is loose. Mine did the exact same thing and it was just a loose wire. As soon as I pluged it in the engine ran normally.
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
some-beach!
Apr 15, 2013 11:18 AM
tdrendel
Dec 11, 2011 08:46 PM
jethrobodean
Oct 22, 2011 07:48 PM
