1984 volvo 240 GL long start
Old Jul 31, 2022 | 09:51 PM
Sulaymaan's Avatar
Default 1984 volvo 240 GL long start
i know these 240s arent 10/10 starting but mine takes 5-6 seconds on the first start, sometimes it shuts off and i restart then its good, and untill it warms up when i rev it hesitates im thinking the fpr im not sure.
Old Aug 1, 2022 | 10:49 PM
could be the FPR. What happens if you jumper the fuel pump relay prior to a cold start to build fuel pressure? It could also be an intake air leak, or the idle air control valve. Finally it could be a coolant temp sensor. Not sure if you have K-Jet or what but there may also be a cold start injector that enriches the mixture for the first 20 seconds or so. I'd see what happens when you jumper the relay, then I'd spray around to look for any vacuum leaks (including the injector seals, vaccuum lines, intake air boot etc) and I'd clean the IAC valve with some carb cleaner as well as the throttle body etc.
raven+crow
Aug 19, 2021 04:36 PM
PSmitty
Nov 8, 2013 10:21 AM
ringoparchesi
Nov 14, 2010 08:58 PM
Kipp
Jan 26, 2009 12:04 AM
