240 Cranks Over But Will Not Start
Old Jan 10, 2009 | 04:39 PM
Kipp's Avatar
Default 240 Cranks Over But Will Not Start
1985 Volvo 240 Automatic. The motor cranks over fine, but will not start? Just smoged a few weeks ago ok. Has a half tank of gas. Fuses are ok. Ideas?
Old Jan 10, 2009 | 04:43 PM
lysmykita's Avatar
Default RE: 240 Cranks Over But Will Not Start
Try starting it with the air mass meter disconnected.
Old Jan 10, 2009 | 06:51 PM
TIPSP's Avatar
Got Boost?
Put a full tank of gas in and then try and start it.
Old Jan 10, 2009 | 07:56 PM
fredbyte's Avatar
Go to www.stepbystepvolvo.com for free guide to diagnosing 740/940 no-starts. This guide is for B230 LH-Jetronic engines. It may help your situation.
Old Jan 12, 2009 | 06:48 PM
Kipp's Avatar
OK. It started with the air mass meter disconnected.I thenconnected it andit started this time also.?????I did nottry driving it or running it very long. So does this tell me that the connection was bad, or do I need to get a new mass air meter?
Old Jan 16, 2009 | 11:32 PM
Kipp's Avatar
Well it started seven times in a row. I was able to run many stops and get some things done today. Tonight I was going to go and visit a freind and it would not start. I disconnected the mass air meter and it still would not start. Iam begining to think that it is just starting every now and then. Mas air meter connected or not. Fuel pump relay maybe? I had it repalced about 7 years ago for doing pretty much what it is doing now as I am remembering.
Old Jan 17, 2009 | 05:25 PM
blue goose's Avatar
Fuel pump relay is a likely suspect. Also the 25-amp fuse holder clipped to the inside left fender. Clean up that 25-amp fuse and try it. If no workie, I would open up the fuel pump relay and inspect the solder joints.
Old Jan 25, 2009 | 10:04 PM
Kipp's Avatar
The 25 Amp fuse looked good. I purchased a fuel pump relay off of ebay $12.00 shipping included. It came Sat. So I installed it and I fired it up. Runs fine,starts fine. All good for now.
Old Jan 26, 2009 | 12:04 AM
blue goose's Avatar
Glad to hear it's fixed. And thanks for posting the fix, that's how we learn.
nightmarevolvo
Feb 4, 2023 06:20 PM
playa7970
Sep 23, 2008 11:50 PM
mracr
Feb 14, 2007 12:53 PM
pmb
Sep 13, 2006 12:15 AM
Ahhsk
Jan 25, 2006 12:15 AM
