240 Won't start
Old Aug 2, 2022 | 09:31 AM
albdfjd's Avatar
Default 240 Won't start
Hello:
New to this forum, thanks for being here.
My 1993 240 will not start (crank) when turning key. If I remove small spade connector located at starter and jumper from there to the larger 12V terminal next to it, she starts. This used to be a very intermittent problem, but now happens all the time. I have already replaced the electronic part of the ignition switch.
Any ideas?
Old Aug 2, 2022 | 11:14 AM
Any ideas?
I've never seen and ignition switch fail in the start position and have replaced hundreds at my shop. They always fail in the accessory position. But - have you checked your neutral starting switch adjustment? Loosen cover around shifter and make sure white pointer is aligned properly in park and neutral?
This is from an earlier car - but is the same switch and adjustment.
Thatcountryboy
Aug 2, 2022 03:43 PM
shobin
May 24, 2021 06:30 AM
jeffersonbernard
Jan 7, 2010 01:54 PM
