1985 Volvo 740 GLE Timing belt
Old Apr 26, 2006 | 09:00 PM
Zebisko's Avatar
Default 1985 Volvo 740 GLE Timing belt
Hello, first post on this forum, looking forward to being here. I have a 1985 Volvo 740 GLE 4 speed+overdrive, and I am replacing the timing belt. Now, what I need to know is, how do you get the bottom part of the cover off? I was looking at it in shop class today, but didn't have enough time to figure it out. Thanks a lot, bye!
Old Apr 26, 2006 | 09:59 PM
Default RE: 1985 Volvo 740 GLE Timing belt
Once the Crank pulley is off there is 2 screws holding the cover on.
One is a 12mm and the other is a 10mm.
NOTEMake sure when you put the Crank pulley back on you get the Tab lined up correctly.
You will see the tab on the crank timing gear once you get it apart.
Old Apr 27, 2006 | 02:26 AM
Zebisko's Avatar
Ok, thanks a lot, that's what I thought I needed to do, but was not sure.
Old Apr 16, 2008 | 12:49 AM
WINDSHIELD's Avatar
Is posible to replace the 740 gle timing belt alone?
alaskabound55
Aug 5, 2013 01:26 PM
rkalybatas
May 8, 2011 01:37 PM
knoman
Jun 23, 2009 08:56 AM
monolith
Apr 16, 2008 12:40 AM
gordon .
Nov 26, 2007 04:40 PM
