1985 volvo 740 turbo troubles
Old Aug 17, 2014 | 02:49 PM
jvinc43's Avatar
Default 1985 volvo 740 turbo troubles
Hi my name is John. I'm new not sure if this is correct spot for technical questions.
I've been having trouble with leaking fuel filter. I think I figured that out thou. Now I have car started with no leaks the inline fuel pump is making a squealing noise. It is also getting very hot. Bout the same as a hot light bulb. Is this normal or is this telling me my pump is bad or another problem. Any insight would be appreciated.
Old Aug 17, 2014 | 03:45 PM
lev's Avatar
lev
I don't know how hot it's getting but the squealing is not a good sign! It does sound like a new pump may be a good idea.
Old Aug 18, 2014 | 07:39 AM
act1292's Avatar
A noisy main fuel pump many times indicates a failed in-tank pump. I would check the in-tank pump and replace as necessary.
Old Aug 23, 2014 | 11:09 AM
jvinc43's Avatar
Thank you. I'll give an update on my car. I replaced the inline (underneath car) fuel pump. It ran great for 5 minutes or so. Then I heard the same noise as before with old pump. It is a whiney sound. Almost as if under pressure. The pump was also hot again too. I've read that it could be a clogged sock filter or is the pump bad?
I'm not too upset, the car is a 1985 with 80,000 miles. So new fuel pumps probably aren't a bad idea anyway. Anyhow I appreciate the input and any advice, tricks for getting the in-tank fuel pump out. Any chance it is the Fuel pressure regulator or the fuel pump relay? Thanks everyone its nice to be able to bounce ideas off of other people thanks again.
John
Old Aug 23, 2014 | 12:36 PM
this guy is replacing a 'regina' pump on a 740 but the procedure is the same for the bosch booster pump..
Volvo Fuel Tank Pump/Sender Replacement
if your car is a wagon, fold the back seats down, then lift the 'flaps' behind the back seats, and remove the couple screws that hold them down and lift those flaps and the half panels they hinge off of back, that will expose the pump access. if its a sedan, its as shown.
SilverSurfer
Oct 18, 2013 10:03 PM
rkalybatas
May 8, 2011 01:37 PM
Arden
Oct 17, 2010 03:38 AM
Scraperondubz
Apr 13, 2009 11:44 PM
imnofreek
May 20, 2007 10:17 AM
