1985 Volvo DL 245 station wagon
Old Jun 21, 2011 | 09:28 PM
DWeston's Avatar
Default 1985 Volvo DL 245 station wagon
I bought this 1985 Volvo DL 245 station wagon and the only way I can get it to run is to spray starting fluid in the throttle body. I have changed both fuel pumps and even put a fuel pressure gauge on the fuel rail. It showed 40 lbs. and then I squeezed the return line and it showed 100 lbs. pressure. Next I bought a fuel pressure regulator and installed it. It then only showed 30 lbs. pressure. I even tried starting it with the return line squeezed off and it still would not start. I think it has do do with the fuel injectors not firing, but I don't know how to fix that. Any help would be appreciated.
Thank you, Don
Old Apr 5, 2019 | 07:07 AM
1967 Tempest's Avatar
Thank you, Don
What did it end up being? I just bought an 86 with the exact same issue. Thanks!!
Old Apr 5, 2019 | 03:58 PM
dweston hasn't posted on this forum since 2011, good luck.
Old Apr 5, 2019 | 04:42 PM
Yup seems like there is always someone who posts and never follows through. i guess Ill have to start a new thread
Phil 850
Oct 16, 2016 12:01 PM
Gardenhands
Jun 6, 2012 08:56 PM
DWeston
Jun 23, 2011 09:33 PM
colt1911
Sep 21, 2010 06:24 PM
copycat923
Jan 27, 2006 01:55 AM
