Fuel injecters won't fire - 1985 Volvo
Old Jun 23, 2011 | 09:33 PM
DWeston's Avatar
Default Fuel injecters won't fire - 1985 Volvo
I bought this 1985 Volvo DL 245 station wagon and the only way I can get it to run is to spray starting fluid in the throttle body. I have changed both fuel pumps and even put a fuel pressure gauge on the fuel rail. It showed 40 lbs. and then I squeezed the return line and it showed 100 lbs. pressure. Next I bought a fuel pressure regulator and installed it. It then only showed 30 lbs. pressure. I even tried starting it with the return line squeezed off and it still would not start. I think it has do do with the fuel injectors not firing, but I don't know how to fix that. Any help would be appreciated.
Violetsjewels
May 25, 2015 09:48 AM
FlyingVee
May 29, 2013 06:05 PM
detestroet
Mar 5, 2012 08:11 PM
nathan7h
May 18, 2009 07:50 PM
petesbween
Mar 6, 2005 01:33 AM
