depressurizing fuel system on '88 240 dl
Old Sep 21, 2007 | 04:44 PM
tanknamedalice's Avatar
Default depressurizing fuel system on '88 240 dl
Okay-
I'm replacing the external fuel pump on my 240 and I'm going through the process of depressurizing the fuel tank. I've got both fuel pump fuses out and I've been letting the engine run for the past 15 minutes. It seems like it should've stalled by now. Am I correct? Have I removed the wrong fuses? Help me out!
Old Sep 21, 2007 | 06:34 PM
Kruspe31's Avatar
Default RE: depressurizing fuel system on '88 240 dl
you are right it should stall. if you have an fpr pull that as well
Old Sep 22, 2007 | 03:39 PM
bigdaddyrdpjr's Avatar
went through the same thing when I wanted to change pressure regulator on 93 244. Never did get it to stall. Ended up doing it without relieving the pressure. Not sure how bad it would be with the fuel pump
Old Sep 22, 2007 | 06:48 PM
83242GT's Avatar
pull the fuel pump relays...they are either up under the passenger kick well or on the driver's side kick well...cycle the key on and off to locate the clicking and remove and the engine should die out farly quickly.
AA752
Mar 28, 2014 09:33 PM
inilegna
Sep 25, 2013 03:27 PM
virginiabowen
Sep 29, 2008 05:31 PM
muckaluster12
Jun 12, 2008 07:31 AM
