Depressurizing fuel system
Old Jun 11, 2008 | 11:02 AM
muckaluster12's Avatar
Default Depressurizing fuel system
I am trying to depressurize the fuel system on a 87 240DL so, I can replace the fuel filter.I have pulled the fuses indicated as the fuses for the [in tank fuel pump # 4 (8 A)] and, the [main fuel pump #6(16A). However; the vehicle continues to idle for a long time without stalling and I can hear a pump continuing to run for several seconds after the ignition is turned off. Any suggestios on how to relieve the pressure?
Old Jun 11, 2008 | 01:13 PM
wojeepster's Avatar
Default RE: Depressurizing fuel system
turn car off. disconnect battery. put wrenches on fuel filter. place rag over fuel filter and wrenches. loosen fastener and soak up small amout of fuel with rag. that is how i do it anyway. remember that this stuff is fire starter and put your careful hat on.
Old Jun 11, 2008 | 05:59 PM
blue goose's Avatar
Agreed. Also remove fuel filler cap from the tank. Sometimes pressure builds up and it's better to vent it.
Old Jun 12, 2008 | 07:31 AM
chimmychong's Avatar
not to sure about your car but in the s40s we have a thing we press ..... its kinda like the button you press down to deflate a tire.....
robingichuhi
Feb 22, 2017 04:34 PM
AA752
Mar 28, 2014 09:33 PM
inilegna
Sep 25, 2013 03:27 PM
tanknamedalice
Sep 22, 2007 06:48 PM
