1987 245dl
Old May 29, 2017 | 06:11 PM
bob 66's Avatar
Default 1987 245dl
Hello, my first post and my first Volvo. I have been fixing several items over the past couple weeks, but came upon a connector that will not come unplugged. It's for the windshield washer pump which is inoperative. Btw, the tailgate washer pump is good. Thanks for helping a new guy.
Old May 29, 2017 | 10:11 PM
have you tried spraying a little kroil or pb blaster on this connector that won't unplug? its likely corroded.
Old May 30, 2017 | 04:23 AM
bob 66's Avatar
Yes, I sprayed the connector with Kroil which loosened the plug. However the connector will only move fractionally up with the release lever all the way open. Working the plug every which way does not release it. It is a plug type I have never seen before, and I figured there must be a trick to it. Thanks for your suggestion.
Old May 30, 2017 | 06:55 AM
John Arsenault's Avatar
Nope there is no trick to it, its just a typical connection. I am thinking maybe the motor fried and cause the connection to weld itself. Just keep working at it.
Old May 30, 2017 | 12:12 PM
bob 66's Avatar
Thanks, John, I will follow your suggestion today and keep working at it and report back. Btw, I have two new pumps on order.
Old May 31, 2017 | 12:19 PM
bob 66's Avatar
The connectors are now both removed from the pumps and are serviceable. In order to accomplish this, I broke off the plastic sides surrounding the pump sockets. Once these were loose, the connectors were easy to unplug. Many thanks to pierce and John for their suggestions and expertise.
Old May 31, 2017 | 05:10 PM
put some dielectric grease in there before plugging into the new pump, the next guy will thank you!
ditto any other connectors you unplug/replug at any point. a bit of silicone dielectric grease on the contacts keeps the corrosion out..
Old May 31, 2017 | 07:07 PM
bob 66's Avatar
That sounds like good advise to me on a connection like that. Thank you for the detailed suggestion.
Old Jun 10, 2017 | 06:46 PM
bob 66's Avatar
Default Washer pumps, 1987 245 DL
To all who helped or are otherwise interested, there is a picture of the new washer pumps in my photo album titled Maintenance. I added some dielectric grease to the connectors for good measure and everything worked okay. Bob
sprlkeyez
Dec 30, 2014 12:35 PM
Sofar.
Jan 14, 2014 01:42 PM
DoctorEmmitLBrown
Apr 1, 2013 07:43 PM
white out
Oct 20, 2008 07:05 PM
tlbacardi
Jan 6, 2004 01:15 AM
