1988 240 DL Wagon w/ 40k miles
Old Mar 31, 2017 | 11:48 AM
steamdonkey's Avatar
Default 1988 240 DL Wagon w/ 40k miles
Newbie here. Any help or advice greatly appreciated.
I have a line on a 1988 240 DL Wagon w/ 40k original miles. Auto trans. It's been sitting since 2011, outside.
Covered in Lichen (live in PNW), but appears to be in immaculate shape underneath all the grime.
Doesn't appear to be any major rust, or any rust.
I'm guessing since it's been sitting since 2011, the gas is bad and I probably shouldn't even try to start it?
I know there are common odometer issues, so I'm not 100% sure the mileage is accurate, but I have reason to believe it is.
I can probably get it for $500 - $1000.
Thoughts? Advice?
Old Mar 31, 2017 | 12:24 PM
Smith Volvo's Avatar
Banned
Thoughts? Advice?
If accurate - it would be the lowest mileage 240 on the planet. Hopefully moisture did not get into the engine in anyway. Would need to flush all the fluids, replace all the belts, tires, etc. Might be a cool barn find. Make sure everything including the engine are free and rotate. If moisture got inside the engine and rusted the cylinders - could be a problem. Price is very fair.
Old Mar 31, 2017 | 09:43 PM
I'd be particularly careful with the brake calibers, sitting that long, there's a good chance there's corrosion in the slave cylinders. even if you flush the brake fluid, and the brakes 'seem' fine, they could fail just a few dozen or 100 miles down the road when the corrosion shreads the piston seals.
go850Turbowagongo
Apr 27, 2012 07:42 AM
760gle
Aug 23, 2011 09:01 PM
auto325
Dec 25, 2010 05:03 PM
timer00
May 21, 2009 07:21 PM
